i try to draw mtext and that what i got
and: MTEXT
Current text style: "Standard" Text height: 0.2000 Annotative: No
Specify first corner: _non
Specify opposite corner or [Height/Justify/Line spacing/Rotation/Style/Width/Columns]:
Cannot find shell program
@Anonymous wrote:
Hi
I use AutoCAD 2014, I start having this problem when I tried to set a new text style to use before that it was okay.
AMAL AMIR
CADD OPERATOR
SKANSKA-JAY DEE JV/ FIRST STREET TUNNEL
2507 FIRST ST NW, WASHINGTON, DC 20001
TEL: 202-450-3006 -EXT. 28
This message, including any attachments hereto, may contain privileged or
confidential information and is sent solely for the attention and use of the
intended addressee(s). If you are not an intended addressee, you may neither
use this message nor copy or deliver it to anyone. In such case, you should
immediately destroy this message and kindly notify the sender by reply email.
Thank you.
I was able to reproduce this issue in 2014 by setting the variable MTEXTED to LISPED.
Reset it to INTERNAL and it should work.
Don Ireland
Engineering Design Technician
The only real problem when discovering new tricks is that you can actually go through years before you reach a real gem that can have a big impact on how things are done. 202-450 Dumps
This is why I offer as many useful tricks as possible on a particular topic to make things easier for future reference. In this article, I will share a series of tips and tricks to create MText objects. If I run just one trick of this article, I will do my job.
Multi-line text objects were introduced in AutoCAD version 13 (1994) and had some basic features such as word formatting and "By-Entity" formatting. Since then, he has become an intuitive and intelligent editor in his place. The purpose of this article is to override the basics.
