AutoCAD Forum
Bluebeam Transparency issue
4 REPLIES 4
1222 Views, 4 Replies
Plotting using Bluebeam if "Plot Transparency" is picked the whole pdf gets pale as if screening was down to 50%.
I am sure Trasnparency is set to "0" for other objects except for the transparent parcel .
And the size is much larger too.
Any options to get around this?
4 REPLIES 4
Alfred.NESWADBA
can you please try to use "AutoCAD PDF (General Documentation).pc3" to plot to PDF and compare the results?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
DWG To PDF works fine!
Alfred.NESWADBA
Then use this device ... at least you know that your drawing settings are ok and AutoCAD can plot this file well. It's then on Bluebeam to handle this correct, worth to ask their support (or forum).
- alfred -
Alfred NESWADBA
pendean
Bluebeam Support is over here https://support.bluebeam.com/
Forma Design Contest
AutoCAD Beta
