Plotting using Bluebeam if "Plot Transparency" is picked the whole pdf gets pale as if screening was down to 50%.
I am sure Trasnparency is set to "0" for other objects except for the transparent parcel .
And the size is much larger too.
Any options to get around this?
can you please try to use "AutoCAD PDF (General Documentation).pc3" to plot to PDF and compare the results?
- alfred -
>> DWG To PDF works fine!
Then use this device ... at least you know that your drawing settings are ok and AutoCAD can plot this file well. It's then on Bluebeam to handle this correct, worth to ask their support (or forum).
- alfred -
