Bluebeam adding (1) to pdf filename when plotting
timothy.d.vu
Message 1 of 12
timothy.d.vu
Does anyone know why bluebeam adds (1) to the filename when plotting to pdf? Is there a way to have that (1) not show up when plotting so I dont have to delete it everytime?
Replies (11)
Message 2 of 12
paullimapa
sounds like a question for bluebeam tech support
in the meantime perhaps try AutoCAD's built-in pdf printers?
Paul Li
IT Specialist
@The Office
Message 3 of 12
pendean
Community Legend
Community Legend
In WindowsOS, a (1) is added to a file name being copied or created if that same exact name already exists at that location. Did you ever notice that?
If Bluebeam does something special beyond that, then you will have to ask BlueBeam Support right here https://support.bluebeam.com/
Message 4 of 12
Ed__Jobe
@timothy.d.vu   In addition to what @pendean wrote, the (1) can get appended to the original dwg. You might be plotting a dwg with that file name? If Bluebeam encounters an existing pdf with the desired filename, it will prompt you to overwrite the file rather than append (1) to the file name. This is the default behavior if you have Append Mode set to Overwrite in the dialog that prompts for the file name of the pdf.
Ed
How to post your code.
Message 5 of 12
timothy.d.vu
the (1) is not being added because theres a file with the same name, I think it has something to do with a page number or something. I've gone to bluebeam support to see if its a bluebeam setting, but was unable to find anything. I came here to see if maybe it was an autocad thing.
Message 6 of 12
timothy.d.vu
The autocad pdf drivers have issues with simplex font ghosting.
Message 7 of 12
pendean
Community Legend
Community Legend
No such thing for most of us that do not use Bluebeam: as a test, open a PDF from one of those drivers in your webbrowsers.
... I think it has something to do with a page number or something...
Where would that come from if I may ask? Perhaps your SSM's list of numbers have not been edited by you to remove them. Explain/elaborate.
Message 8 of 12
timothy.d.vu
it definitely happens using autocad pdf drivers. Opening pdf's created by autocad pdf drivers that has simplex font either with adobe or bluebeam, creates a ghosting effect like a shimmer on all the texts.
Im only guessing bluebeam adds the (1) as a page number but actually trying to confirm why it adds the (1), I dont know for sure. I know blue beam uses filename+layout+(page#?) as the default filename when plotting pdf. So far there are no settings on bluebeam to change this nomenclature that i can find.
Message 9 of 12
pendean
Community Legend
Community Legend
There is no such naming feature in AutoCAD sadly, not in our offices for any of our users anyway.
Message 10 of 12
Ed__Jobe
I didn't realize you are using the Bluebeam printer driver. Use the Bluebeam plugin on the Output tab and it won't add the (1). It only uses the file name and not the layout name.
Ed
Message 11 of 12
cadbob
It drove me nuts recently, but here is the fix.
1. Page Setup
2. Properties
3. Ports Tab
4. Check Plot to File
5. Save
I don't believe you can do today's job with yesterday's methods and be in business tomorrow.
Message 12 of 12
Ed__Jobe
The fix to what? It still appends the layout name to the file name.
Ed
