Autocad 2022 migration file
cleftwich
cleftwich
I currently run Acad 2022 and I have a new machine. I exported my 2022 settings and I was wondering if I install 2023 on my new computer with the 2022 migration file work for 2023
pendean
Community Legend
Community Legend
2023 has a "migration" option as part of the first-start option, you would use that: you should have seen the exact same thing when you installed 2022, did you not?
Also like your 2022 installation that you can look at right now, 2023 will also have a MIGRATE FROM AN OLDER VERSION tool found under your Windows Button that you can use later if you missed the startup option.
The only caveat: 2022 and 2023 need to be both running on the same computer for the migration between versions tool to work.
If you are on a MAC.. you are in the wrong forum but I suspect it might be similar, you'll have to confirm in that MAC forum for sure.
HTH
WeTanks
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
cleftwich
Thank you
cleftwich
Thank you very much
