I need to explode this block reference but it will move far away. How to explode this block reference properly?
Thank you in advance for any help.
I didn't have any problem to explode your block and it didn't move neither...
More explication on your problem?
Rgds
Thanks for your reply.
I use EXPLODE command to explode this block reference.
Then it moves far away...
Here are some screenshots.
Have you check your layers?
Attached the same file, I just exploded...
Instead of EXPLODE try BURST command.
Finally I use another Autocad version to explode the block and it works normally.
Maybe my Autocad 2015 is corrupted.
