620 Vistas, 5 Respuestas
Block Reference Problem
I need to explode this block reference but it will move far away. How to explode this block reference properly?
Thank you in advance for any help.
Guillaume.Desmedt
en respuesta a: Anonymous
I didn't have any problem to explode your block and it didn't move neither...
More explication on your problem?
Rgds
Guillaume DESMEDT | BIM Infra Guy
en respuesta a: Guillaume.Desmedt
Thanks for your reply.
I use EXPLODE command to explode this block reference.
Then it moves far away...
Here are some screenshots.
Guillaume.Desmedt
Have you check your layers?
Attached the same file, I just exploded...Emoticono indiferente
Slawomir_
Instead of EXPLODE try BURST command.
Etiquetas (2)
en respuesta a: Slawomir_
Finally I use another Autocad version to explode the block and it works normally.
Maybe my Autocad 2015 is corrupted.
