Hi
AUTOCAD LT 2018 user here...
I have edited a few components within a block including the location of tag and prompt text, once complete and saved I return to the paper space the text still remains in the old location.
There doesn't seem to be a way of altering this, I thought that if I alter the location in the block editor the text should shift with it.
I'm obviously missing something.
Any ideas where i'm going wrong, I've hunted high and low.
Many thanks
Alex
Solved by user181. Go to Solution.
Hi @Anonymous, try using the ATTSYNC command and select the block to update the attributes after you modify the block.
