AutoCAD Forum
BLOCK CRASH
7 REPLIES 7
Message 1 of 8
379 Views, 7 Replies
BLOCK CRASH
I AM EDITING A BLOCK OF A TOILET .
THE DRAWING AND AUTOCAD SHUTS DOWN (NOTHING NEW).
THE THING THAT REALLY CHANGED WAS WHEN I TRIED TO RECOVER THE DRAWING  THE BLOCK WAS THE ONLY THING THAT WAS LEFT IN THE DRAWING EVERYTHING ELSE WAS ERASED. NOW ALSO THE SIZE OF THE FILE DIDN'T CHANGE BUT EVERYTHING IS GONE EXCEPT THE BLOCK. AM I MISSING SOMETHING?
PLEASE HELP
THANKS
Tags (3)
7 REPLIES 7
Message 2 of 8
natasha.l
Hello @Anonymous,
Thanks for posting.
I see that you mentioned, "THE DRAWING AND AUTOCAD SHUTS DOWN (NOTHING NEW). " does this often happen to you?
When does it happen? Only when you edit this block? Or on other occasions, please explain?
Message 3 of 8
in reply to: natasha.l
It doesn't happen everyday but it happens . It doesn't just happen when editing a block it just happens at random times.  Usually its no big deal because I recover the drawing but this issue is something new that I have never seen before.
Message 4 of 8
Alfred.NESWADBA
that happened when service packs were not installed.
Can you please start command _ABOUT and send us a screenshot from that dialog?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 5 of 8
in reply to: Alfred.NESWADBA
Here is my screen shot
Message 6 of 8
Alfred.NESWADBA
thank you for your screenshot, you should install update 2019.1.2
For your defect drawing, I guess it's lost so take care with your BAK file so you don't lose the previous version.
A small chance I have seen in some rare cases like yours: start command _INSERT and go through all blocks, it might be that one of them is your previous model space content.
- alfred -
Alfred NESWADBA
Message 7 of 8
I understand.
Strange thing is the file is still the same size as if all the information is still in it.
Message 8 of 8
Alfred.NESWADBA
as I wrote, I guess the BAK file is the best you currently have.
You might upload the dwg-file, maybe there exists a small chance to get your modelspace back (please describe or show us anything so we know what you expect to have in the modelspace ... and so we know what we have to search for).
- alfred -
Alfred NESWADBA
Forma Design Contest
