I AM EDITING A BLOCK OF A TOILET .
THE DRAWING AND AUTOCAD SHUTS DOWN (NOTHING NEW).
THE THING THAT REALLY CHANGED WAS WHEN I TRIED TO RECOVER THE DRAWING THE BLOCK WAS THE ONLY THING THAT WAS LEFT IN THE DRAWING EVERYTHING ELSE WAS ERASED. NOW ALSO THE SIZE OF THE FILE DIDN'T CHANGE BUT EVERYTHING IS GONE EXCEPT THE BLOCK. AM I MISSING SOMETHING?
PLEASE HELP
THANKS
PLEASE HELP
THANKS
Hello @Anonymous,
Thanks for posting.
I see that you mentioned, "THE DRAWING AND AUTOCAD SHUTS DOWN (NOTHING NEW). " does this often happen to you?
When does it happen? Only when you edit this block? Or on other occasions, please explain?
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
Thanks for posting.
Natasha
Helpful Links:
It doesn't happen everyday but it happens . It doesn't just happen when editing a block it just happens at random times. Usually its no big deal because I recover the drawing but this issue is something new that I have never seen before.
that happened when service packs were not installed.
Can you please start command _ABOUT and send us a screenshot from that dialog?
- alfred -
- alfred -
Here is my screen shot
thank you for your screenshot, you should install update 2019.1.2
For your defect drawing, I guess it's lost so take care with your BAK file so you don't lose the previous version.
A small chance I have seen in some rare cases like yours: start command _INSERT and go through all blocks, it might be that one of them is your previous model space content.
- alfred -
- alfred -
I understand.
Strange thing is the file is still the same size as if all the information is still in it.
I understand.
as I wrote, I guess the BAK file is the best you currently have.
You might upload the dwg-file, maybe there exists a small chance to get your modelspace back (please describe or show us anything so we know what you expect to have in the modelspace ... and so we know what we have to search for).
- alfred -
- alfred -
