so ive been drawing this whole plan without checking the bearing and distance of the line (my mistake) and I think it shouldn't be a problem. then, I check every line ive drawn and it shows that the bearing displace slightly from the bearing I type earlier.the drawing is exact with the plan but the bearing some what like it's move.Is it just a thing that can be ignored or I should redraw or is it my lisp or my autocad need to be fix?
It is very difficult to say based on your description, whether it is your workflow, or a custom program that you are using. do you have any pictures or drawings you can share that give an example of the issue you are seeing?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Check your drawing settings. Within the Transformation tab - look for a specified grid rotation angle (bottom right).
Could it be only that the displayed bearing is rounded to some cruder precision than the values you typed in, but that the bearing is actually correct? For instance, say you drew something at a bearing of N23d31'54"W, but when you check it with LIST or in the Properties palette, you see just N23dW [displayed value only rounded to the nearest degree]. Check the setting of the AUPREC System Variable [= Angular Units PRECision] -- increase it to show down into the arc-minutes and arc-seconds.
