Kent1Cooper
en respuesta a: Anonymous
Could it be only that the displayed  bearing is rounded  to some cruder precision than the values you typed in, but that the bearing is actually correct?  For instance, say you drew something at a bearing of N23d31'54"W, but when you check it with LIST or in the Properties palette, you see  just N23dW [displayed value only  rounded to the nearest degree].  Check the setting of the AUPREC System Variable [= Angular Units PRECision] -- increase it to show down into the arc-minutes and arc-seconds.
Kent Cooper, AIA
