656 Vistas, 3 Respuestas
Bearing inserted is not same with bearing it should be
so ive been drawing this whole plan without checking the bearing and distance of the line (my mistake) and I think it shouldn't be a problem. then, I check every line ive drawn and it shows that the bearing displace slightly from the bearing I type earlier.the drawing is exact with the plan but the bearing some what like it's move.Is it just a thing that can be ignored or I should redraw or is it my lisp or my autocad need to be fix?
