I am having trouble with my line type display, the batting linetype just shows up as many dots instead of the batting that I want.
I have tried several things:
- Command REGEN
- Command 3dConfig - Disabled Hardware Acc
-Tried restarting Cad/ my machine
AND to make things even stranger, sometimes the batting actually appears in the drawing. But then if I close it and re-open the drawing it goes back to just looking like many dots...
I have attached my file so you can see if you can fix the issue. Please help!!!
Solved by pendean. Go to Solution.
This did not work.
when I type the command linetype - LOAD I get the following error:
Bad definition of BATTING at line 125 of file C:\Users\Patrick\appdata\roaming\autodesk\autocad lt 2016\r22\enu\support\acadlt.lin
Then the BATTING linetype does not show up.
Bad definition of BATTING ....
Does it happen to be the last linetype definition in the file? If so, make sure there's an empty line below it, i.e. that the file ends not with the end of that definition but with a hard return.
@pendean wrote:
.... BATTING uses a custom SHP font file to create that shape, yours is missing from your setup ....
One way to check whether it's a missing .SHX file: does the same happen if you try to load other linetypes that use Shapes, such as [assuming LT also has these] the FENCELINE ones? Their embedded Shapes are in the same file as the one for BATTING, so presumably you'll get the same message if the file is missing.
This makes sense. I got a new computer at work recently, and ever since installing AutoCad this has happened.
Any idea how to fix this?
That suggests that the Whatever.shx file is missing, but then, that doesn't accord with Message 1 where you said that BATTING sometimes appears as expected. I don't know what else to suggest, other than maybe you have an unstable connection to wherever the file is.
