AutoCAD Forum
Batch Plot
8 REPLIES 8
Message 1 of 9
shawn.wirth
2467 Views, 8 Replies
Batch Plot
How to I set my batch plot so I only get one single PDF file instead of multiples ones.
8 REPLIES 8
Message 2 of 9
JTBWorld
in reply to: shawn.wirth
See Multi-sheet file setting in PDF Publish Options Dialog Box.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 3 of 9
If the above tip does not work, change the PUBLISHCOLLATE variable to 0.
Message 4 of 9
shawn.wirth
Good to go. Thanks all
Message 5 of 9
shawn.wirth
How do I get to the PDF Option with the "Multi Sheet" options? I can't find it
thanks
Message 6 of 9
Multi-sheet button is here. What multi-sheet options are you looking for ?
Message 7 of 9
ruelc
in reply to: dany_rochefort
Hi Danny,
What do you do when the "publish option" button is idle? I am using Acad 2024.
Message 8 of 9
paullimapa
in reply to: ruelc
Make sure you’ve installed the latest 2024 updates
Paul Li
IT Specialist
@The Office
Message 9 of 9
TomBeauford
in reply to: ruelc
If you're simply Publishing a hard copy the button would be idle as there wouldn't be any options to set.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Forma Design Contest
