How to I set my batch plot so I only get one single PDF file instead of multiples ones.
Solved by dany_rochefort. Go to Solution.
Solved by JTBWorld. Go to Solution.
See Multi-sheet file setting in PDF Publish Options Dialog Box.
If the above tip does not work, change the PUBLISHCOLLATE variable to 0.
How do I get to the PDF Option with the "Multi Sheet" options? I can't find it
thanks
Multi-sheet button is here. What multi-sheet options are you looking for ?
Hi Danny,
What do you do when the "publish option" button is idle? I am using Acad 2024.
If you're simply Publishing a hard copy the button would be idle as there wouldn't be any options to set.
