BAK Files Not Saving to Specified Folder
silverlineinformation
Bought a new computer earlier this year and upgraded to AutoCAD 2025. I like to keep my bak files in a separate folder than the original dwg file. I used the MOVEBAK command to select the folder I want to keep them, like I have done with previous versions of CAD. It worked for a while but now all the bak files are saving to the folder with the dwg files. When I use MOVEBAK, it still has the folder I selected to save them to but it does not save to that folder. I can retype the file path in and it will work for a minute but it always goes back to saving the bak files with the dwg file.
jreidKVSUZ
Very easy fix.
Type OP or CONFIG.
Pick onto Automatic Save File Location. Make a folder.
I always use AUTODESKs folder because it is easy to find.
Be sure to set your Auto Save Time as well.
Hope this helps!!
JRR!
paullimapa
Make sure you download and install 2025.1 update
Paul Li
IT Specialist
@The Office
Appreciate the reply, but the autosave feature is different than the the bak files.
Ran the update and it appears to be working so far. I'll respond if anything changes. Thanks for the help.
paullimapa
Glad that worked out for you…cheers!!!
Paul Li
IT Specialist
@The Office
