AutoCAD Forum
Automate block attributes
4 REPLIES 4
madhuryya_prakash
419 Views, 4 Replies
Hi all, I am working on a project, where I need to create grading levels for roads. I have attached the drawing showing one such instance. Could anyone help me automate the process so that I can reduce the manual feeding of data for hundreds of other locations. Thanks in advance!
4 REPLIES 4
3wood
in reply to: madhuryya_prakash
Please try attached dwg.
The first block can not have any prefix, number only. You can redefine it so it has another attribute to represent the prefix.
madhuryya_prakash
in reply to: 3wood
Thanks @3wood , this works like a charm, I was wondering if you could explain or show me the concept of how to create one, I know it's related to insert fields, have tried a few steps, but unable to get the desired result!
3wood
In the field, insert a formula first. Then in the formula, right-click and insert another field. The imbedded field is the value of the first block attribute.
I can post some detail steps if you need detailed explanation.
madhuryya_prakash
in reply to: 3wood
Hi, @3wood , it works now, thanks for your detailed explanation.!
Forma Design Contest
AutoCAD Beta
