AutoCAD Forum
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
29 REPLIES 29
Message 1 of 30
36656 Views, 29 Replies
I have two student installs
one on home system one on laptop
I can open and edit all files on home system and school computer, but on my laptop, i get this message
Autodesk DWG.  This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
worked  fine the first time i open cad and edited a drawing, and has had this red screen and message ever sence.
29 REPLIES 29
Message 21 of 30
cadffm
There is no problem, OR?
But if you want to change: DWGCHECK
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-91E890BF-AEBD-4BCE-9663-1AFD595AA5E4
Sebastian
Message 22 of 30
in reply to: Emmsleys
Even I am facing the same issue as in once you open the file ,the dwg is completly empty with no cursor as well,the cursor appears on the tab but not on the model space along with the dwg
@Emmsleys wrote:
Ok so to recap;
  • Happening with all files even a brand new file
  • Unable to see new lines on drawn BUT are you able to see any work within a working drawing file?
  • ONLY happening on your LAPTOP. PLEASE provide your system specs, which other releases you have/had of AUTOCAD on this operating system.
  • If you suspect it is a graphics issue, have you verified your hardware meets the AutoCAD system requirements
  • any recent updates made to your graphics card? Have you applied them.
Troubleshooting steps you should try;
  1. Log on as a different windows user, does the issue still happen?
  2. Uninstall/ Re-install Microsoft C++
  3. Uninstall/ Re-install Microsoft .NET
  4. Reset to settings to defaults
  5. Apply all updates/service packs
If that still doesn't not help or work I would recommend a Selective start up and then a uninstall/reinstall
Steps for a selective start-up
  1. On the keyboard, hold down the WINDOWS key and then hit R.
  2. In the Run window, type MSCONFIG and then click OK.
  3. Click on "Normal startup" if it is not selected already.
  4. Under the Services tab, at the bottom of the window put a check on "Hide All Microsoft Services" and then click "Disable All."
  5. Under the Services tab, put a check in front of the FLEXnet Licensing Service; there could be two and may include 64 in the name.
  6. Under the Startup tab, click "Disable All."
  7. Click OK and then click Restart when prompted.
Turn off antivirus or internet security software if it has re-enabled itself. If it still works good under a selective startup, then go back into MSCONFIG and turn on all the services and reboot. This will tell you if the issue is coming from a service or a startup item. Once you know that, you can then go through the list, turning on one or two at a time (make notes as you go along), using a process of elimination to find the conflicting item.
To put the computer back to a normal startup, open up MSCONFIG again and click "Normal startup" under the General tab. Click OK and then Restart.
Message 23 of 30
cadffm
And have you understood all the hints and tested, why are you just writing here
that you have the same problem, even though there is already this extensive answer?
Go through the steps, if you lack knowledge on individual points then write it down in detail,
Point by point. Everything you do not write, both positive and negative, we can not know.
The first test: Disable hardwareacceleration, command 3dconfig
Is it working now?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Mouse-...
Sebastian
Message 24 of 30
Me pasa lo mismo 😞 al final pudo solucionar ese problema?
Message 25 of 30
Alfred.NESWADBA
post 13 in this thread is marked as solution, you should start there...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 26 of 30
What the solution? I didn't get it. Please, let me know.
Message 27 of 30
cadffm
Able to post a reply, but not able to read (the thread, or just the as solution marked answer)?
What is YOUR problem?
About the message from topic
https://forums.autodesk.com/t5/autocad-forum/autodesk-dwg-this-file-is-a-trusteddwg-last-saved-by-an...
Otherwise, write about your problem
Sebastian
Message 28 of 30
in reply to: pendean
If I am getting above message when opening a Dwg file, does that mean -we cannot make any change in that? Or can we proceed with making update in that drawing and save and proceed further.
Message 29 of 30
cadffm
It means NOTHING, except the file was saved by a non AutoDesk/RealDWG software
and in this case, AutoCAD can not know about problems which could appear, because of unexpected data.
It's just a warning, nothing more.
You can disable the check - if you like (for me: I like the check&informations as text in my textscreen only..
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-91E890BF-AEBD-4BCE-9663-1AFD595AA5E4
Sebastian
Message 30 of 30
mikababic2201
Lost dwg document. I had not save it corect. How can find it
Forma Design Contest
AutoCAD Beta
