Autocad wont open side by side configuration error
My AutoCAD 2017 application wont open. I keep getting the error in the screen shot below. I have tried uninstalling and reinstalling the program but still get the same error. Please help.
ennujozlagam
@Anonymoushello, try to run as administrator OR try to install latest updates and service packs and see if this helps. thanks
imadHabash
Hi and Welcome to AutoDesk Forum,
it's a Microsoft visual C++ problem, i suggest to follow this >>> Link <<< to solve your issue.
Imad Habash
john.vellek
Hi @Anonymous,
This error message means that you have a problem with Windows. I suggest going through the steps in this article to reinstall C++ and then also check for all Windows Updates.
Please go through this process and update your status with another post.
John Vellek
john.vellek
Hi @Anonymous
I am checking back to see if my post or others helped you with your side-by-side configuration problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
mmuzisiwayo
Community Visitor
Community Visitor
it is usually an issue with MS c+++ redistributable. You can easily fix by reinstalling this found on the your path drive C:\Autodesk\AutoCAD_2015_English_Win_64bit_dlm\3rdParty\x64\VCRedist
