Viewport Creation
Viewport Creation
Viewport Creation
In model space the "Model Viewport" panel is active. When going into paper space the panel goes Grey / is Inactive.
How, having moved to paper space, deleted the default viewport, and then pasted a title block upon the standard sheet, do I create/place a new viewport within it?  There must be a simple answer. All advice appreciated.
Mike Hall.
Kent1Cooper
Welcome to these Forums!
VPORTS command
Kent Cooper, AIA
Patchy
Make a layer name VIEWPORT or something like that
Use command MVIEW and make a rectangle.
Then you have to choose a scale to zoom the drawing that shows on model space.
imadHabash
Hi and Welcome to AutoDesk Forum,
@Anonymous wrote ( ...When going into paper space... ) if do you mean the Layout space,when you move to the layout you will found that rectangular viewport which you can use it by clicking inside it. and for making another viewports you can do it by Mview command line.
Imad Habash
Dear Mr. mikejh
I have created some similar sort of environment as you replicated and managed to create a screen cast.
Hope this could help you
Regards
Di****h
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
There are some great suggestions here to help you get your viewport(s) created.  Did you have any success with this or do you still need a bit more help?
John Vellek
