AutoCAD Forum
Dim text auto change height
12 REPLIES 12
Message 1 of 13
790 Views, 12 Replies
Hi everybody,
I'm facing issue about text height of dim. By only one dim style, but there have 2 heights of the text ( see below image ).
Please give me some suggests.
Thanks all !
12 REPLIES 12
Message 2 of 13
Patchy
One is annotative and the other two are not.
Click on the dimension, look in the Properties Palette, what does it say?
Message 3 of 13
in reply to: Patchy
Hi Patchy,
I relize that there're have a special info : "dim scale overall"= 53.9.
In dim setting, this value is 20. It automatic changed.
Message 4 of 13
Dear Mr. dgkhoa89
Please find the attached screen cast.
Hope this could help you.
Regards
Di****h
Message 5 of 13
Hi di****hmc,
Thanks for your help!
That is a good solution, however i think it is a temporary solution.
I wish the DIM auto chose correct scale, it's mean we don't have to use command "update" to edit them.
About this problem. At the first i just use Autocad, every thing okay. After i install a program that run based on Autocad ( wood CAD CAM ), i realize this problem. It may be bring to you some data.
Message 6 of 13
john.vellek
Hi @Anonymous,
Welcome to the Autodesk Community!
It appears that the dimension on the left is using a different (Annotative) dimstyle.  Can you attach your file so I can take a look for you and perhaps get you running a bit better?
John Vellek
Message 7 of 13
in reply to: john.vellek
Hi john.vellek,
Please help me check this file.
Thanks you !
Message 8 of 13
Hi all,
I see that this file work okay on acad, but wood CAD CAM (wCC) is not. wCC run based on acad, however i don't know why dim function is not good.
I hope have someone here can fix this issue while i wait for support from wCC.
Thanks all !
Message 9 of 13
john.vellek
Hi @Anonymous,
I see that none of your dimensions are annotative in this drawing. To correct the one dimension that has larger text I just used matchprop to select one of the correct dimensions and then clicked the one on the left.
An easy fix. I hope this helps,
John Vellek
Message 10 of 13
Patchy
Out of the box, autocad hardly causes dimoverride.
Anytime a person use autolisp or add-on and they're ill-written and that's the reason.
You have to monitor your commands with SYSVARMONITOR and stop using the bad commands.
Message 11 of 13
Thanks John.vellek,
Yes we can use matchprop to fix it. However I really need to know the reason. We will not waste time to fix.
Regards !
Message 12 of 13
john.vellek
Hi @Anonymous,
As @Patchy mentioned, you likely have a lisp routine or some other macro that has done this. You can try doing things manually for a bit to see if the problem reoccurs.
John Vellek
Message 13 of 13
in reply to: Patchy
Hi @Patchy@john.vellek
Follow your guide, i opened system variable dialog. Here're so many command, thus i don't know how to check all.
I have no  experience about this. Please give me some suggest.
Thanks you!
AutoCAD Inside the Factory
