AutoCAD - Startup opens a new drawing
jduframe
Message 1 of 13
jduframe
I have always had Startup of AutoCAD open in the startup menu, but lately it has been opening Drawing1.dwg
I have checked Startup which was set at 3, and Startup Mode set at 1
Startup set at 1 or 3 both do the same thing, I think something else go messed up.
Startup set at 2 is similar but does not have the top ribbon like before.
what else could be causing this?
or am I remembering this wrong and initially with the startup menu the top ribbon does not exist?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (12)
Message 2 of 13
handjonathan
Hi @jduframe
Thanks a lot for posting your question to the forums!   The startup variables are explained here. I think you need to set it to 1 to get the behavior you want.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 3 of 13
jduframe
Startmode is set at 1, this is correct,
Startup (System Variable) is the one that I believe is not working correctly, when I set Startup at 1 or 3 they both perform the same.
what I am looking for is Startmode 1 & Startup 3, I just though it had a top tool bar or ribbon before. not sure now?
Message 4 of 13
jduframe
Startup 2 seems to be more of what I was use to having, I will leave it at that, just thought I remembered having a top ribbon or that the tool bar was larger at the top, something was bit different.
Message 5 of 13
Ed__Jobe
For me, STARTUP = 3, the default, displays the ribbon. Are you saying that if STARTUP = 1 then no drawing1 is created?
Ed
How to post your code.
Message 6 of 13
jduframe
no I am saying Startup 3 creates a drawing1.dwg, which I have never had happen before, not sure if that is what setting 3 is suppose to do, but I change it to 2 now so I don't have drawing1.dwg when I open AutoCAD
Message 7 of 13
Ed__Jobe
Open the Registry Editor and navigate to Computer\HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R24.2\ACAD-6107:409\Profiles\<<VANILLA>>\General. The actual key may vary, depending on what software you use, but it will be under the current profile. When STARTUP = 3, the key UseStartupDialog should not exist. If you have STARTUP  set to 1 or 2, then the key will be created. Check to see if that is happening. When you make a change in AutoCAD, you have to hit F5 in Registry Editor to refresh the screen.
Ed
Message 8 of 13
jduframe
I don't see R24.2
Message 9 of 13
Ed__Jobe
Like I said, the numbers will be different depending on your software. 2022 is R24.1, Click on 5101 until you get down to the profile and then General.
Ed
Message 10 of 13
jduframe
oops I actually thought you meant the ending part of the Key, I actually seen AutoCAD 2023 available for download and was in process now of installing that, since I have extra time between projects right now.
Message 11 of 13
jduframe
i went back into registry and i have no startup key in either AutoCAD 2022 or AutoCAD 2023
Message 12 of 13
jduframe
although startup menu looks fine now
Message 13 of 13
Ed__Jobe
If the key isn't there, then you have STARTUP = 3.
Ed
