Autocad linetype scale problems
Renee_Ve
Renee_Ve
I have an excisting series of drawings,
where i use linetype scale 20 (1:1) on autocad iso dashed lines  and its shows properly and the same in both model space and layout .
in 1 drawing so far it won't show in the layout it looks continious.
I found out that if | adjust the scale to around  0.1 I can see it in the layout (but modelspace is continious now very unpractical to work with)
I just cannot find the setting what cause this
any clue how yo fix this numeric problem?
Thanks in advance.
Accepted solutions (3)
user181
Check the variable PSLTSCALE in the layout that the lines are continuous and set it to 0 if your LTSCALE is 20
rwrightWMDSY
Try setting PSLTSCALE to 1
Renee_Ve
Thanks for the tips!.
PSLTSCALE is on 1 already and it does not help
PSLTSCALE on 0 seems to help but it shows only in plot preview strangely enough!
user181
After setting PSLTSCALE to 0 you need to do a REGENALL to see a difference on screen.
