AutoCAD Forum
AutoCAD - "-LAYER SET - END"
8 REPLIES 8
Message 1 of 9
khvPGX5G
501 Views, 8 Replies
Hi All
I have an layer "text", to which i would like to change to!
When inserting "-LAYER S text" in commandline I end up stuck in not being able to close command
other than two times enter button
Question: What are the "code" to end the current command?
[ The subject line of this post has been edited for clarity by @handjonathan Original: -LAYER SET - END ]
Tags (1)
8 REPLIES 8
Message 2 of 9
ВeekeeCZ
in reply to: khvPGX5G
-LAYER S text;;
When you try to do it in the command line, you need to hit ENTER twice. So add ;; to make it in macro.
Or better use
-LAYER M text;;
M (as Make) option not only set the current layer (as the Set option), but it also creates the layer if it doesn't already exist.
Message 3 of 9
khvPGX5G
Hi
I do not want to use macro at this point !
I use excel to copy paste into autocad
A copy paste of that line with ;; are not being accepted by autocad 2020 (see attached)
Message 4 of 9
imadHabash
All what you have to do is just type the exact layer name.
Imad Habash
Message 5 of 9
ВeekeeCZ
Also can use a new line character (enter)
-layer set text
This also can be done in Excel by Alt+Enter. But then you can't directly copy-paste the code into AutoCAD, you need to use that Notepad to remove the initial and last ", then copy-paste it into AutoCAD.
Message 6 of 9
khvPGX5G
The "CLAYER TEXT" copy to autocad works perfectly to my need,
but still is left to how to get out off the -layer command back to main command line (no enter)
Message 7 of 9
khvPGX5G
in reply to: ВeekeeCZ
Please send this "Unless you're on LT, you can use (setvar 'clayer "text") " so i can accept the solution
this are not 100% perfect but a great help!
Message 8 of 9
paullimapa
this will work as long as you don't have a space in the layer name (include space after 1 at end of line :
EXTNAMES 0 -layer _set text EXTNAMES 1
Try copy and paste above line into command prompt
Paul Li
IT Specialist
@The Office
Message 9 of 9
ВeekeeCZ
Ohh, I removed that by accident. sorry.
Forma Design Contest
