Unable to open DXF file in Autocad
Message 1 of 21
Hi ,
I am using AutoCAD 2014-English version. I couldn't open a DXF file which is exported from one of the Oasys product (Adsec 8.4.10). While opening, it shows the attached message and closes without any warning/Error message upon pressing 'Enter'. Please note I am able to open the file in other drawing viewing software.
Please find attached the DXF file and let me know the reason for this issue and how can I resolve it.
Best Regards,
Karthik Appakutti
karthik.appakutti@arup.com
Replies (20)
Message 2 of 21
tmccar
Hi Are you sure that the DXF file is not corrupted? For one thing, it looks very small (1K). Could you have it re-exported?
Message 3 of 21
Thanks for your response. I am sure that the file is not corrupted. I am able to open the file in other drawing viewing software.
Message 4 of 21
m_kingdon
Have you tried the RECOVER command?
Mike Kingdon
Civil 3D Zealot
Message 5 of 21
pendean
Community Legend
Community Legend
FWIW a dxf file is a text file, nothing more: open your 1kb file in your favorite word processor and read the content. It seems to contain one polyline with some vertices. Is that your "complex section"?
999
created by Section Export
0
SECTION
2
ENTITIES
0
LWPOLYLINE
8
Oasys-0
62
0
90
4
70
1
10
0.
20
0.
10
-632052.
20
367620.
10
-443646.
20
1015840
10
363528.
20
1170460
0
ENDSEC
0
EOF
Message 6 of 21
pendean
Community Legend
Community Legend
Yes, I was right, it's just a PLINE that you could have easily receated in AutoCAD.
Your DXF file opened fine in another Cad program I use for situations like these.
Message 7 of 21
artc2
Your dxf file is an entities section only file. AutoCAD only supports these in the R12 DXF format. Since an entities section only file doesn't have a version specifier, AutoCAD assumes that the file is an R12 version. The LWPOLY entity type did not exist in the R12 DXF format, so AutoCAD can't read the file in as an R12 dxf file and errors out.
Message 8 of 21
Hi m.kingdon,
As I told, the file gets closed soon after opening. So it is not possible to use RECOVER command.
Message 9 of 21
Hi Pendean,Yes, its a simple polyline. Please dont relate the file name with the autocad entity. 😛
Message 10 of 21
Hello Pendean,
I can recreate since it is a simple section. But please note that the file is exported from a software, therefore what is the point in recreating it again. All I need is AutoCAD should be able to read the exported file else I can report to the software support ( The software from which DXF file is exported). Thanks for your response.
Message 11 of 21
Hello artc2,
Thanks for your response. I hope your post will help me to solve the problem.
Message 12 of 21
m_kingdon
To use the RECOVER command AutoCAD needs to be open.  Start AutoCAD with a blank drawing, enter RECOVER into the command line and select the file you are trying to open.
Mike Kingdon
Civil 3D Zealot
Message 13 of 21
pendean
Community Legend
Community Legend
Basically, the source application does not create AutoCAD-compliant DXF files.
Since Autodesk is the entity that created the DXF format, they strictly enforce compliance. Do not ignore the well detailed response you got from Autodesk direct in post #7 above. You can't ignore that reality.
So your choices are to get a 3rd party CAD file that can read those bad DXF files and save to DWG file for you to open in AutoCAD (like I did), or find another program to translate your Oasys files to DXF (not likely). Go talk to Oasys about a fix.
Good luck.
Message 14 of 21
hello,
I have the same problem, I want to open a dxf file in autocad civil. after the "presse enter" message nothing happen.
there is a solution to open the file?
thank you
Message 15 of 21
cadffm
If you knew it was the same problem, you would know how to solve it 😉
Where is the file?
Is it an ASCII or BINARY DXF?
Without a file we can not help you. Upload your DXF file and we take a look.
Sebastian
Message 16 of 21
hi, can you help me fix this dxf file.i can not open it. thanks
Message 17 of 21
Alfred.NESWADBA
If you would upload the file, we might be able.
But without the file, without knowing the message you get, without knowing the AutoCAD version you are using, ... we can't.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 18 of 21
Message 19 of 21
Alfred.NESWADBA
>> here is it
Sorry, a bit more information about this file would be great ... just uploading a file without any information is not the way I prefer. I want to know what I have to look for and what happens on your system using which software/release.
- alfred -
Alfred NESWADBA
Message 20 of 21
cadffm
@Anonymous
here is it
Many associations are corrupt, but the main drawing can be recovere.
That's what I think as well
@Alfred.NESWADBA  schrieb:
Hi,>> here is it
- alfred -
Sebastian
