Whenever I open a new dwg AutoCAD opens a separate CAD instead of opening the new drawing on the dwg which is already opened. As in it doesnt place them on the tabs but open a separate CAD altogether.
Why would this be happneing?
CC
CC
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Try setting SDI=0 to see if that remedies this behavior. Here is an article that explains how it can be used.
Hi @Anonymous,
