AutoCAD Forum
Unhandled Exception 1 (Access Violation Reading 0x0000) at address BB3A76FDh
9 REPLIES 9
Message 1 of 10
726 Views, 9 Replies
I'm trying to open up dwg file that works on 3 other machines except mine. Purged and saved to earlier versions doesn't help. I get number of errors-all relating to access violation and after all of this fatal error . Any suggestions?
9 REPLIES 9
Message 2 of 10
pendean
Your AutoCAD version is? Theirs are?
Windows version on all PCs are?
Post that problem DWG file here for us to try it as well.
Message 3 of 10
john.vellek
Hi @Anonymous,
More than just Purge, there are other steps that can be taken"
  • Audit
  • Purge
  • -Purge>All
  • -Purge>Regapps
  • -Exporttoautocad
  • Insert into another drawing as a block.
Please attach your file and I can take a look at it for you.
John Vellek
Message 4 of 10
in reply to: pendean
Carlson Survey with  Autocad Mechanical 2015 SP2 on Win7 Pro is on my machine. It works on my coworker machine with the same applications.
Message 5 of 10
in reply to: john.vellek
John,
Please see attached cad file.
Thanks.
Message 6 of 10
wispoxy
I opened the DWG and the file seems fine. I believe it's your PC or AutoCAD.
Please share your PC and AutoCAD specs.
Message 7 of 10
in reply to: wispoxy
Autocad Mechanical 2015 SP2 with Carlson Survey 2016
Message 8 of 10
john.vellek
Hi @Anonymous,
I opened your file and ran Audit - It found numerous errors.
I also ran Purge and -Purge>regapps.
Try my version of the file and see if you still have issues.
John Vellek
Message 9 of 10
wispoxy
I want to help you, but I can't find an AutoCAD Mechanical 2015 trial. I only opened it with AutoCAD 2015 and 2017.
Message 10 of 10
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
AutoCAD Inside the Factory
