I'm trying to open up dwg file that works on 3 other machines except mine. Purged and saved to earlier versions doesn't help. I get number of errors-all relating to access violation and after all of this fatal error . Any suggestions?
Hi @Anonymous,
More than just Purge, there are other steps that can be taken"
Please attach your file and I can take a look at it for you.
Hi @Anonymous,
Carlson Survey with Autocad Mechanical 2015 SP2 on Win7 Pro is on my machine. It works on my coworker machine with the same applications.
John,
Please see attached cad file.
Thanks.
John,
Thanks.
I opened the DWG and the file seems fine. I believe it's your PC or AutoCAD.
Please share your PC and AutoCAD specs.
Autocad Mechanical 2015 SP2 with Carlson Survey 2016
Hi @Anonymous,
I opened your file and ran Audit - It found numerous errors.
I also ran Purge and -Purge>regapps.
Try my version of the file and see if you still have issues.
Hi @Anonymous,
I want to help you, but I can't find an AutoCAD Mechanical 2015 trial. I only opened it with AutoCAD 2015 and 2017.
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
Hi @Anonymous,
