AutoCAD object become darker
Message 1 of 10
I'm not sure what have I do before, but is there any way to make the object become brighter? I have checked the visual style, color layer, lighting, sun, and anything that is related to light but the color still looks different. Original.PNGAfter (darker).PNG
Replies (9)
Message 2 of 10
Patchy
You have them on locked layers
Message 3 of 10
Valentin_CAD
@Anonymous ,
If the drawing is Xref, adjust the settings in the OPTIONS > Display > Fade Control.
Consider this other link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 10
All the layer is unlocked. I have tried lock and unlock again but it still looks dark.
Message 5 of 10
Hi Valentin, only some of the object are XREF, but I also tried to adjust the value but all the object still looks dark.
Message 6 of 10
Valentin_CAD
@Anonymous ,
The best option is for you to post the drawing.
In the mean time,
  1. Check its not a setting on your monitor or TV picture mode.
  2. Set  CETRANSPARENCY = ByLayer
  3. Set  VSFACEOPACITY <-60>
Your last resort would be to Reset to Default (link).
Emilio Valentin
Message 7 of 10
dgorsman
Wild stab in the dark, have you started the REFEDIT command?  This will dim content not in the XREF or block reference being edited.  Telltale sign, is there are a handful of contextual panels added to the Ribbon to save-and-close, exit-without-save, and transfer content between the edited XREF/block and the drawing context.
Message 8 of 10
Thank you for all the support, but it still looks dark. I have attached a google drive link here. I would be happy if anyone can solve it. Thank you.
https://drive.google.com/file/d/13cgl8k84mmmP43KB2oz9GKOvwkpN51AC/view?usp=sharing
Message 9 of 10
pendean
Community Legend
Community Legend
Change your SHADEMODE setting to anything other than SHADED
Message 10 of 10
nkirton
THis was my fix just now. Thanks!
Nathan Kirton
If what I said helped you out, please use the ACCEPT AS SOLUTION or KUDOS buttons.
"I don't know why it doesn't work. It fit in the model!"
