AutoCAD - Moving 3D Objects in One Axis or Plane Using Point Filters, Relative Coordinates Not Working
To put it simply, I'm trying to precisely move objects around in 3D space relative to other objects without using the 3D Gizmo. I'm often trying to do this in an orthogonal view such as Front, Left, etc. (I'm avoiding the 3D Gizmo at the moment because it only works in 3D wireframe and it often appears in the middle of the 3D object; it has to be relocated to the desired location on the object before the move can happen.) Point filters seem to be the most promising way of doing this but I just can't get them to work right.
Let's say I invoke the Move or 3DMove command because I want to move an object in only the Z direction. I click on a base point on the object. I invoke a point filter of .z and select a destination reference point, perhaps on some other object at a different elevation. The object is moved to that z value but then AutoCAD is asking me for xy coordinates before it will complete the move. I want the xy coordinates to remain unchanged. I was only trying to move the object in the z direction. How do I tell it to just use the existing xy coordinates of the base point? A relative coordinate of 0,0? No dynamic input is giving the desired result... @0,0,0, #0,0,0, *0,0,0 all try to move the object to the drawing origin. Enabling ortho only seems to help if I'm in a 3D view and not an orthogonal view.
Perhaps the answer is the 3D Gizmo is the only effective way of making these kinds of moves, I just don't understand why point filters can't be used reliably in a similar way. I'm 95% of the way there but I can't tell it NOT to change the values of the other coordinates. I have the same issue if I'm moving in two axes at once. If I use a .xy point filter to specify the destination point it then wants a z value... but I don't want the z value to change.
For context, I'm a long-time Vectorworks user and I'm used to making single-axis/planar moves of 3D objects from orthogonal views with essentially no problems. In AutoCAD, I'm finding it constantly wants to throw objects forward and backward in the screen plane when I'm in a front or side view, for example. This seems to happen no matter what combination of snaps I try. Ideally, it would be nice if there was a way to tell AutoCAD to just restrict movements to the screen plane in certain contexts. Front view? Only allow movements in XZ. Left view? Only allow movements in YZ. Such behavior would be much more convenient. Vectorworks seems to do this innately.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Moving 3D Objects in One Axis or Plane Using Point Filters, Relative Coordinates Not Working ]
