Autocad Menu
Autocad Menu
Autocad Menu
Is there anyway to change the appearance of Autocad menu from "tileblocks" to "text menu"?
Bijan
Accepted solutions (3)
Ed__Jobe
Map 3D has a "Classic Workspace". Check your workspaces to see if your product includes such a workspace. If not, you can create your own. First create a new workspace. Then, set MENUBAR to 1 and run the RIBBONCLOSE command. You may need to edit the cui to add menus to the menu bar.
Ed
How to post your code.
john.vellek
Hi @Anonymous,
There are some options for you regarding the interface.  The small down arrow on the right side of my image will let you collapse/expand the Ribbon as desired. In addition, the little arrow at the left side of my image shows where you can enable the Menu bar.
I hope this helps.
John Vellek
cwr-pae
@john.vellek's way works fine, or you can set menubar to 1 or add the line (setvar "menubar" 1) to your acaddoc.lsp to force the menu on always.
john.vellek
Hi Bijan,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Hi John,
Thanks for your help and explanation. It helped me to resolve the issue.
I am sorry for my late respond.
