Switching between blocks by name
merd94
merd94
Hi, does anyone knnow hot to switch between blocks by name.
For example i've created two blocks, block 'a' and 'b', after inserting 10 blocks of 'a' i need to replace only three of them to block 'b'. Any suggestions?
Replace block in express tools doesnt work, it replaces all of them. However i need to change selected only.
imadHabash
in general blocks replacement will not serve your issue . i don't exactly how is your case look like BUT as you describe that you want to replace just 3 of blocks to another kind block and this is mean ( some how ) that you have a same base point. i think the fastest way is just to copy block B over block A then erase unwanted ones. you may have different case than the one that i imagine it ... please if you want to share with us your case you can attache a screencast or the CAD file itself to see how it could be done .
Regards.
Imad Habash
MikeKovacik4928
The issue of replacing only selected instances of blocks, can be solved with
this little lisp routine which I got off someone on this forum previously.
Only problem is you have to enter in name of replacement  block by typing in rather than
selection. Then you can choose by selecting, and the blocks you choose, will be replaced.
Appload the routine, and the type BRS to run
See attached
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
StephenThomasGrace
You can use the clipboard and express tools for this little trick
select all the blocks you want to keep and copy with basepoint, 0,0..
Then delete them.
Now use the express tools replace block.
That will fix all the remaining blocks
Then clipboard > paste to original coordinates to retrieve your original blocks.
The clipboard allows you do all sorts of stunts like this.
-steve
merd94
Thanks, that exactly what i wanted
MikeKovacik4928
Glad I could help.
Mike
MikeKovacik4928
Steve
That is a good work around.
It is what I also used to do, until I got hold of the lisp.
the lisp is a lot quicker and less painful!
Mike
