I have autocad LT 2013, the problem is it keeps saving every 20 min, and it keeps saving several times.and whenever it happens it takes 5-8 min to come back to normal. i have turned off autosave and reinstalled autocad with deleting all preferance, and i even reinstalled OS(operating system), it is still happening. please help
Thanks in advance
have you try to install autodesk updates and see if helps. thanks
A hint: If you decide to reinstall AutoCAD, you have to do a CLEAN reinstall before. (In your case: You should also clean the registrry, because the value of SAVETIME is stored there)
A tip: If you cant find what causes this strange behavior you can setz the SAVETIME to a very high value (e.g. 600). So an automatic saving will done only every 10 hours.
Jürgen Palme
The problem isn't autosave. It's either an extremely bloated .dwg, an inadequate computer/network, or too many background processes running. Slow autosave is only a symptom of a larger issue.
Where I work the network settings keep Autosave turned on. I turn it off but it keeps turning back on. IT keeps it that way. However, I have found that I can control the amount of time between saves. I have it set to the max of 600 minutes. I suggest you try that. AutoCAD's autosave is a terrible feature that doesn't work well in my opinion. I haven't used it in decades???? I rely on QSAVE via CTRL+S and archiving files.
@BrianBenton wrote:AutoCAD's autosave is a terrible feature that doesn't work well in my opinion. I haven't used it in decades???? I rely on QSAVE via CTRL+S and archiving files.
Terrible feature for use as a back-up is correct because it wasn't designed for regular back-ups. You are expecting the wrong thing from it. Autosave files are temporary files so one can recover lost work in case of a crash. The files should be deleted automatically when AutoCAD is exited gracefully. It works perfectly for what it is designed for.
@RobDraw wrote:Terrible feature for use as a back-up is correct because it wasn't designed for regular back-ups. You are expecting the wrong thing from it. Autosave files are temporary files so one can recover lost work in case of a crash. The files should be deleted automatically when AutoCAD is exited gracefully. It works perfectly for what it is designed for.
This is a great perspective I haven't thought of before. It might not be designed to be a backup, but most users think of it that way. But I would also say that as a safety net in case of a crash, it still doesn't perform well.
@BrianBenton wrote:But I would also say that as a safety net in case of a crash, it still doesn't perform well.
There was a time when it was a tool that I used frequently. If it didn't work, I wouldn't have been using it. When I saved people from having to do hours of work over again, I'd say it functioned as designed. It was a miracle in their eyes.
