I have alot of annotation set up on several drawings and it was set up by putting in a leader (arrow) and then entering text seperately. Now I am trying with difficulty to change the existing text and leaders to multileaders with mtext. I have created a multileader style in the style manager tool but I can not seem to change the existing text to it. I am also looking to make the leader so that it is always at right angles to the first polyline of the leader if that makes sense. Is this possible and am I missing something simple?
@Anonymous,
john.vellek has edited your subject line for clarity: Annotation
Solved by john.vellek. Go to Solution.
Solved by AllenJessup. Go to Solution.
Solved by pendean. Go to Solution.
There is nothing built in AutoCAD to convert separate floating leaders and text objects to MLEADERs. You will need to use something like this LISP instead http://cadtips.cadalyst.com/multileaders/leader-multileader
Can you show us in an image what you mean with your second question? Or show us the problem you are having in an image? Or both?
I want to change it from standard straight arrow to a polyline arrow which I can do. But I have being requested to set it up so that the right angle will not change, essentially lock into place even if I move the main leader. I cant attach the screenshot now
I don't have access to the program right now. Off the top of my head you could use TXT2MTXT to convert the text to mtext. Then use QLATTACH to attach the Mtext to the leader. I don't know how to turn the single leaders to Multi-leaders.
Allen Jessup
CAD Manager - Designer
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I found this utility in the Autodesk App store. It should help to convert Leaders to Mleaders.
The QLattach command that @AllenJessup mentions can be found in the Express Tools.
Perhaps you can also combine the steps into a Macro using the Action Recorder.
Please share a sample file for the formatting questions so I can better understand what you are trying to create.
I use a utility from the AutoCAD App Store called LeadertoMleader. I pick the existing leader, then the text and viola!
I'm looking to turn leaders into a multileaders without text. I want to do this so I can add vertices to the leader.
Do you know how to accomplish this without making new multileaders and deleting the old leaders?
As Dean said it's probably easier to delete and just add an new multileader. Every other option is going to be just as many clicks as that. If all the ML you need to do this too will have the same amount of vertices you need to add, it's probably faster to make a ML style with that many vertices already. Then just deleting and adding that new style will be your fastest solution as adding the vertices will be much faster.
If you need MLs with different numbers of vertices all over the drawing you could get crazy and make a ML style for each number of vertices like 1,2,3,4,5 vertices. Make a ML pallet and drop each style on the pallet. You then need a ML with 3 vertices just click the pallet button for the 3 vertices ML and add it. If that's something you do often or there are a ton to change the pallet is probably worth it.
Nick DiPietro
Cad Manager/Monkey
Hi @Anonymous,
Here is another thread that might help you with a lisp routine to do this. I have not tried it myself but it looks promising.
@Anonymous wrote:
No, I don't think it would be as fast or as efficient.
Which brings up the question as to why you are making the change in the first place?? Leaving it alone would be infinitely faster and more efficient.
I suggested deleting and redoing because it's easier to add the extra vertices that way that you said you needed. Yes it might be a couple more clicks but adding vertices after the fact is more of a pain than doing them from the start.
Anyway here is my lisp that I use to convert leaders to multileaders. You need to shut off running snaps for it to work correctly. If you don't then the ML and text can move to nearby snaps.
Nick DiPietro
Cad Manager/Monkey
