AutoCAD Forum
Lisps Not Automatically Loading
7 REPLIES 7
Message 1 of 8
738 Views, 7 Replies
I have multiple lsp files that I have loaded using appload.  I click the option to add them to the startup suite and history, and they are in the startup suite and show in my history.  However, when I open a drawing, they do not automatically load.  Every time I open a drawing, I have to go back to appload and load the lsp files again.  Why are they not loading each time I open a drawing?  Thanks for your input.
7 REPLIES 7
Message 2 of 8
john.vellek
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 I assume that when you load them manually, that the LISP routines work properly.  Do you get a security warning when you do?
Please check your Trusted Locations in OPTIONS to make sure that the location of the LISP files is there.
John Vellek
Hi @Anonymous,
John Vellek
Message 3 of 8
pendean
pendean
Community Legend
Community Legend
Message 4 of 8
in reply to: john.vellek
I have all the locations as trusted.  And yes, when I load manually they all work.  I do not get any error messages.
Message 5 of 8
john.vellek
john.vellek
Hi @Anonymous,
Try adding them in the CUI instead then as @pendean has suggested.  Please let me know the results.
John Vellek
Hi @Anonymous,
John Vellek
Message 6 of 8
Yes...they show up there too already...and I have the path as trusted.
Message 7 of 8
cadffm
cadffm
Add only one lisp woth the content:
(Princ "That works!")
And try it again.
Is it working?
Ok.
Solution:
Create a s::startup function to load your stuff when acad is ready with loading a drawing file.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/autorun-custom-command/td-p/8100740
Sebastian
And try it again.
Is it working?
Ok.
Solution:
Sebastian
Message 8 of 8
in reply to: cadffm
Got it resolved.  I think I had some conflicting paths and the lsp files were overwriting each other.  Thank you for everyone's help!!
AutoCAD Inside the Factory
