AutoCAD Forum
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Autocad Layout view style issues
20 REPLIES 20
Message 1 of 21
alessandro_udina
1058 Views, 20 Replies
While using autocad for 3d modeling, I couldn't change the view style in the layout, if I try to change it from 2d wireframe to any other style the console sends an error message (example: "unknow command conceptual"). The viewing styles work properly only in the model. I even tried to reset to default settings and I re-installed the program but it doesn't work.
20 REPLIES 20
Message 2 of 21
Problem only on this dwg or all dwgs?
Executive About command do screenshot and list that here
Also execute GraphicsConfig do a screenshot and post that
Paul Li
IT Specialist
@The Office
Message 3 of 21
"...if I try to change it from 2d wireframe to any other style the console sends an error message (example: "unknow command conceptual")."
What method are you using to change the visual style?
Message 4 of 21
I tried whit console commands and with the view menu in the layout.
Message 5 of 21
Apparently on all dwgs. Anyways thanks I'm going to try it later and let you know
Message 6 of 21
also share one sample drawing where this happens
Paul Li
IT Specialist
@The Office
Message 7 of 21
Please be more specific.
Show us a screenshot of the command line, or the buttons/controls you use.
Message 8 of 21
Maybe my graphics card is obsolete? It might be since I0m working on a very old pc
Message 9 of 21
2025 has an update
Paul Li
IT Specialist
@The Office
Message 10 of 21
Message 11 of 21
as you can see it's locked on wireframe view
Message 12 of 21
What happens when you enter comnand
_.Vscurrent
conceptual
Paul Li
IT Specialist
@The Office
Message 13 of 21
dmfrazier
in reply to: paullimapa
Yes, it seems that the Ribbon control is "executing" the option but not the command.
Is that something an out-of-date graphics driver can cause?
Message 14 of 21
paullimapa
in reply to: dmfrazier
Try downloading and installing the 2025 update first
Paul Li
IT Specialist
@The Office
Message 15 of 21
it says "cannot set a visual type in paper space"
Message 16 of 21
I'm currently using autocad 2025
Message 17 of 21
I know but you only have v58
The 2025.0.1 update when installed gets you to v72
Paul Li
IT Specialist
@The Office
Message 18 of 21
cadffm
in reply to: alessandro_udina
sorry for this stupid question, but all your picures from layout are all made while in Paperspace..
The message "cannot set a visual type in paper space" is correct, if you tried to set it while in paperspace.
Also your picture of error message was made while in paperspace.
Go to your Layout, jump into your viewport - command MSPACE
and try it again.
Sebastian
Message 19 of 21
alessandro_udina
in reply to: cadffm
omg thank you, I didn't know how to use the layout for 3d modeling, I always draw 2d things. I typed mspace and now the view in the layout works as the model space.
Message 20 of 21
alessandro_udina
in reply to: cadffm
Using modelspace in the layout to make visual styles work won't cause any problem while trying to print the views into a pdf file right?
Forma Design Contest
