AutoCAD LAG
AutoCAD LAG
AutoCAD LAG
Hello, I'm currently working on some housing floor plans and everything was working fine up until a week ago. However, AutoCAD recently started to lag whenever I try to pan or to draw a straight line and I cannot work efficiently. I have the student version (2021), can someone please tell me how I can fix this? Thank you.
Patchy
Audit, Purge, unload all xref.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forums. Welcome to the Autodesk Community!
I am sorry to hear about the lag. Did anything change around the time this started occurring? Is it only with certain files?
A lag can often be caused by out of date graphics drivers, corrupt files, file location (like cloud), or limited system resources (such as can occur when connected to a VPN). The following Autodesk Knowledge Network (AKN) articles provide known solutions:
Slow or poor performance in AutoCAD
Cursor is slow, jumpy, or jerky in AutoCAD
Please let us know if this helps.
Please click the Accept Solution button on any posts that resolve the problem or answer your question.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
