3D Solid Taper - Error Code 97030
cjt285BL
cjt285BL
Does anyone know if AutoCAD has a published list of error codes with descriptions?  Trying to taper a face of a 3D Solid and I get:
"Modeling Operation Error:
Error Code Number is 97030"
Thank you.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @cjt285BL,
I am sorry to hear you are getting a modeling error code. I am not aware of a published list, they are generated based on cause, version of product, and operating system.
Most of the modeling error I have worked to resolve occur when either the function results in a self-intersecting solid or it causes previously connected entities (lines, surfaces, or fragments) to no longer be connected. The error is the result of the process not being allowed, and failing to complete.
Let me know if this helps.
Please click the Accept Solution button on any posts that resolve the problem or answer your question.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
