Pdf Import is not bringing in all objects
I have a building section in PDF form.
I attempt to use the PDF import function in AutoCAD 2020.
Almost none of the objects within the PDF are imported into AutoCAD.
What can I do/ change to import the PDF?
[Images embedded in post for clarity by cheryl.buck]
Accepted solutions (3)
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I can't tell for certain from the image, but it looks like there may be some Raster content in the PDF.  Try checking the Raster option in the PDF import to see if that helps.
If not, I'd be happy to check it if you want to send the PDF.
Please click the Accept Solution button on any posts that resolve the problem or answer your question.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
pendean
Community Legend
Community Legend
RASTER elements in a PDF are never converted: only VECTOR elements. Check it yourself with this box
From what I understand that brings it in as a bitmap image.
My end goal is to use AutoCAD to work with the PDF as if it were an AutoCAD dwg
and not just have an image of the building section.
The image I attached was another building section that I imported (not as a raster image)
and I was able to edit within AutoCAD.
ParishSouthBdx
depending on how the pdf file was built initially, you may not be able to realize all entities becoming workable graphics within the cad file it's underlayed.
pendean
Community Legend
Community Legend
Post your problem PDF file please: glad to see a different PDF worked, but that means nothing except your AutoCAD is working like ours with the correct PDF type.
