AutoCAD installer launches when Quickbooks Pro Timer is launched
Message 1 of 8
Hi.  I am new to this forum.  When my client launches Quickbooks Pro Timer, AutoCAD installer launches and gets some error.  I have uninstalled and reinstalled Pro Timer, then uninstalled it and installed AutoCAD 15 SP2, then Pro Timer, but she still gets the same.  I understand others in her org are seeing the same thing.  Installing the AutoCAD patch fixed it for some but not all.  Anyone ever encounter this?  I found a post from 2009 for the same but that's it.
Thank you,
Miles W
Replies (7)
Message 2 of 8
Alfred.NESWADBA
welcome @Anonymous!
Which error?
It is important to know the type and content of the message otherwise it's a zero-information.
What you can try: right-click the launcher of Pro-Timer and use "start as administrator" ... then let the installer from AutoCAD do it's job (as it then run in administrative context too).
Good luck, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I don't believe that Intuit supports the Quickbooks timer anymore.  I remember battling it in an installation a couple of years ago. If it is an absolute must in the environment how many computers are affected by this behavior?  Have you tried a clean uninstall of AutoCAD and an uninstall of the timer and then reinstalling the Timer and finally AutoCAD? I believe that is how I finally got it to work.
Before you go through that it would be interesting to see if a current version of AutoCAD would display the same issue?  Is it possible to install a Trial to see if it replaces a DLL or registry setting? I doubt that it will but would be fairly quick and easy to test.
John Vellek
Message 4 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Alfred's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 5 of 8
spatmon
Hi John.  I have the same issue as the person with the original email.  However, it only occurs on one of the computers in the office.  In general, the problem occurs without any autodesk software running.  It references Autodesk DWG True View.  It says to run Run Setup.exe.
Message 6 of 8
Alfred.NESWADBA
sorry, I'm not John, but have you tried my suggestion (about starting as admin ...)?
- alfred -
Alfred NESWADBA
Message 7 of 8
spatmon
Alfred,
Yes, I did, but it didn't resolve the issue.
Steve J. Patmon, AIA
Message 8 of 8
Alfred.NESWADBA
what happens if you login with another Windows user account?
- alfred -
Alfred NESWADBA
