AutoCad Improvement Forum?
nickada
Message 1 of 8
nickada
Is there a suggestion Forum for AutoCad like the one for Inventor? For some reason, I can''t seem to find it.
Replies (7)
Message 2 of 8
brian.strandberg
I thought there was an AutoCAD Ideas forum but I can't find it.  I use the Civil 3d ideas one alot.
Maybe try the Augi wish list.  I know the autodesk developers pay attention to it.
https://www.augi.com/wish-list
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 3 of 8
paullimapa
always the feedback one:
Welcome to our Feedback Community (autodesk.com)
Paul Li
IT Specialist
@The Office
Message 4 of 8
handjonathan
Hi @nickada
Thanks a lot for posting your question to the forums!   There is no equivalent to the Inventor idea station but product feedback can be submitted here or as @paullimapa suggested via the Autodesk Feedback community.
I hope this helps.
Jonathan Hand
Technical Marketing Manager | Construction
Message 5 of 8
Kent1Cooper
It's not quite like a Forum, in that while you can submit feedback, there's no exchange, no threads with replies, etc., but maybe you can use the >Product Feedback Page<.
Kent Cooper, AIA
Message 6 of 8
pendean
Community Legend
Community Legend
@nickada What suggestion are you trying to ask for? More often that not, there is already a solution if it is actually and remotely feasible. Tell us more.
Message 7 of 8
nickada
@pendeanLike I said in my originel post, I mostly use Inventor, but these three things would be nice:
1. I work with many people who do not use AutoCad, so they often share dxf files. I have seldom been able to import a dxf directly into AutoCad. Someone on a forum suggested using onlineconvertfree.com, and it worked! I suggest that AutoDesk update their dxf import software so it works.
2. My AutoCad skills are not what you'd call great. Several times, especially after receiving help, I've accidentally overridden a drawing I didn't mean to. It would be nice if AutoCad automatically saved the drawing one is opening and/or saving in an "Old Versions' folder like Inventor does. That way one can always recover an older version of ones work. There is a system variable that sets how many versions to save, if any.
3. Someone sent me this link to an article about a problem I was having. I wanted to print it, and even though it is about a half page long, my printer wanted to put in on 5 pages.
It would be nice if there was a print function on articles like this so one can print it without wasting a tree.
Message 8 of 8
pendean
Community Legend
Community Legend
@nickada Got it, you have no suggestions, just a need to seek out easier-to-use DXF/DWG compatible software since you find AutoCAD hard to use.
In which case, you can start here https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Impor...
and https://www.google.com/search?q=inventor+tip%3A+how+to+imnort+dxf+files
More tips on how to get the most out of your Inventor software can be discussed here
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
And you can ask for more features here https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Then offer up whatever it is you wish to share about AutoCAD with Autodesk here https://www.autodesk.com/company/contact-us/product-feedback
And might I suggest... try to find easier to use DWG/DXF software here if that online tip offered by others stops working for you
https://all3dp.com/2/best-autocad-alternatives/
https://www.google.com/search?q=alternates+to+autocad
Good luck.
