AutoCAD Forum
AutoCAD - How to explode a drawing view
13 REPLIES 13
Message 1 of 14
7106 Views, 13 Replies
Hey, I need to explode a drawing view in order to make some corrections in a cut view. But I am now allowed to use command "explode". What should I do? Here are some photos to get a better idea
[ The subject line of this post has been edited for clarity by @handjonathan Original: How to explode a drawing view ]
13 REPLIES 13
Message 2 of 14
ampster40
ampster40
going by the cell phone camera pic (printscreen - save to file works too), that appears to possibly be an Inventor titleblock - which if that is the case, and this file has been saved out of Inventor as an "Inventor .dwg" file type, you will not be able to explode the view I believe. If it came out of Inventor and you need to be able to edit it in Acad, save the file out of Inventor as a "AutoCAD .dwg" file type. I'm aware there are differences between the .dwg file types that Inventor creates, I am not very familiar with the appropriate work flow concerning each different file type - other than there are some differences and I think you found one of them HTH
Message 3 of 14
well yeah. it is .dwg
I added the file it self
Message 4 of 14
Patchy
Patchy
I can't find out why, anything in this dwg. can be exploded
Message 5 of 14
EXPORTLAYOUT will create a new drawing and the separate views will become blocks that can be exploded.
Message 6 of 14
in reply to: Patchy
They are views created by VIEWBASE Actually the border can be exploded.
Message 7 of 14
dbroad
dbroad
Rather than explode the views, why don't you change the 3d part in model space? The views will automatically be updated.
Architect, Registered NC, VA, SC, & GA.
Message 8 of 14
in reply to: dbroad
I knew I should have suggested that.
Message 9 of 14
man i was looking for it for ages, thanks a lot !
Message 10 of 14
Kevin.Spear
Kevin.Spear
in some cases, I need the "view" exploded so I can define a 2D block in model space to make an "assembly."
Kevin
Kevin Spear, PE
Kevin
Kevin Spear, PE
Message 11 of 14
THANK YOU SO MUCH!!
THANK YOU SO MUCH!!
Message 12 of 14
shashikantpandeypandey
Observer
Observer
use EXPORT LAYOUT command, it will create new drawing through which you fine tune your drawing.
Message 13 of 14
ENG_PATRYCK
ENG_PATRYCK
Você me salvou, obrigado!
Message 14 of 14
clacampos
in reply to: ENG_PATRYCK
clacampos
Olá @ENG_PATRYCK
Bem vindo a Auodesk Community.
Nos temos foruns em português para os principais produtos da Autodesk neste link.
https://forums.autodesk.com/t5/portugues/ct-p/156
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
Olá @ENG_PATRYCK
Claudia Campos
AutoCAD Inside the Factory
