Hey, I need to explode a drawing view in order to make some corrections in a cut view. But I am now allowed to use command "explode". What should I do? Here are some photos to get a better idea
[ The subject line of this post has been edited for clarity by @handjonathan Original: How to explode a drawing view ]
Rather than explode the views, why don't you change the 3d part in model space? The views will automatically be updated.
I knew I should have suggested that.
in some cases, I need the "view" exploded so I can define a 2D block in model space to make an "assembly."
use EXPORT LAYOUT command, it will create new drawing through which you fine tune your drawing.
Olá @ENG_PATRYCK
Bem vindo a Auodesk Community.
Nos temos foruns em português para os principais produtos da Autodesk neste link.
https://forums.autodesk.com/t5/portugues/ct-p/156
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
