Hi.
Using AutoCADLT 2025.
Problem:
- When drawing both 'polyline' and 'line' using Hidden/Centerline/Dashed linetypes, a gap starts to form between the final dash and the end vertex of the line as the line lengthens.
Info:
(in the following 'line' refers to both polyline on line)
- The gap between the last dash and the end point vertex of the line remains even it is drawn as a single polyline/line.
- This means that some corners have gaps.
- This issue occurs with PLINEGEN variable set to both 1 & 0.
- This issue occurs when manually enabling/disabling 'line type generation' in properties once the polyline is selected.
- Filleting/joining these lines does not solve the problem.
- Exploding and then filleting/joining these lines does not solve the problem.
- The gap only occurs on the end point of the line. Not the start point.
- When stretching the line, whether using start point or end point to stretch, the gap on the end point grows.
- This issue does not occur on other work computers using the exact same layer, linetype, linetype scale and same dwg.
I have attached a .png to demonstrate the issue.
Any help on this would be greatly appreciated.
Thank you very much.
Solved by BigBoyCAD. Go to Solution.
Solved by paullimapa. Go to Solution.
have you installed the latest 2025.1 LT update?
Hi Paul.
Yes I have the most recent update installed.
Unfortunately the problem persists.
On this particular computer does the same problem occur in a new drawing?
What if you create a new Windows profile with local admin rights and then sign in using that new profile?
Worse case would be to do a Reset
in case it's a graphics card issue, try disabling Gfxdx12 by setting that to 0 and then restart LT.
Update:
It seems the issue may be caused by a variable on my computer.
The issue transfers to another computer when a .dwg I created is opened on the other computer.
I have tried resetting AutoCAD. It didn't fix the problem.
I tried all else to no avail... then changing the 'Gfxdx12' variable to '0' sorted the issue.
Thank you very much mate.
Greatly appreciated.
Glad to have helped…cheers!!!
