AutoCAD - Hidden line/Centerline/Dashed line won't join at vertices. Gap between final dash and end point vertex of line.
BigBoyCAD
BigBoyCAD
Hi.
Using AutoCADLT 2025.
Problem:
- When drawing both 'polyline' and 'line' using Hidden/Centerline/Dashed linetypes, a gap starts to form between the final dash and the end vertex of the line as the line lengthens.
Info:
(in the following 'line' refers to both polyline on line)
- The gap between the last dash and the end point vertex of the line remains even it is drawn as a single polyline/line.
- This means that some corners have gaps.
- This issue occurs with PLINEGEN variable set to both 1 & 0.
- This issue occurs when manually enabling/disabling 'line type generation' in properties once the polyline is selected.
- Filleting/joining these lines does not solve the problem.
- Exploding and then filleting/joining these lines does not solve the problem.
- The gap only occurs on the end point of the line. Not the start point.
- When stretching the line, whether using start point or end point to stretch, the gap on the end point grows.
- This issue does not occur on other work computers using the exact same layer, linetype, linetype scale and same dwg.
I have attached a .png to demonstrate the issue.
Any help on this would be greatly appreciated.
Thank you very much.
Replies (7)
paullimapa
have you installed the latest 2025.1 LT update?
Paul Li
IT Specialist
@The Office
BigBoyCAD
Hi Paul.
Yes I have the most recent update installed.
Unfortunately the problem persists.
paullimapa
On this particular computer does the same problem occur in a new drawing?
What if you create a new Windows profile with local admin rights and then sign in using that new profile?
Worse case would be to do a Reset
How to reset AutoCAD to defaults (autodesk.com)
Paul Li
IT Specialist
@The Office
paullimapa
in case it's a graphics card issue, try disabling Gfxdx12 by setting that to 0 and then restart LT.
Paul Li
IT Specialist
@The Office
BigBoyCAD
Update:
It seems the issue may be caused by a variable on my computer.
The issue transfers to another computer when a .dwg I created is opened on the other computer.
I have tried resetting AutoCAD. It didn't fix the problem.
BigBoyCAD
I tried all else to no avail... then changing the 'Gfxdx12' variable to '0' sorted the issue.
Thank you very much mate.
Greatly appreciated.
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
