AutoCad doesn't show dashed line in model view
Message 1 of 41
AutoCad doesn't show dashed line in model view, even when i adjust the scale nothing chances
Replies (40)
Message 2 of 41
Usually when that happens to me, I need to adjust the ltscale in increments until I see a change. Change it from .1 to 100 in small increments (or have you done that already?)
Message 3 of 41
Check your MSLTSCALE. Set to "0" and see if that helps.
Message 4 of 41
pendean
Community Legend
Community Legend
What are your settings for CELTSCALE, LTSCALE and MSLTSCALE in that problem file? Hint: a setting of 1 is a good place to start, REGENALL after making any changes.
Message 5 of 41
No difference 😞
Message 6 of 41
all the settings are set to 1. I have this problem with all the new files i create
Message 7 of 41
How big is your drawing titleblock going to be? Your ltscale will play a part in that. Will you be scaling your titleblock up, or using paper space to facilitate views?
Message 8 of 41
I've tried that before with no results
Message 9 of 41
pendean
Community Legend
Community Legend
How long is your line?
How far away fom 0,0,0 is your line?
If you zoom in real close and REGENALL do you see the dashed?
If you select the line does PROPERTIES list it as dashed? Does PROPERTIES show the LINETYPE SCALE as 1.0 or something else?
Do you just need to reload your linetypes?
Message 10 of 41
can you share your dwg with us, or a screencast of you checking the settings of the line you are having a problem with?
Message 11 of 41
No dashed line even when i zoom in
Message 12 of 41
pendean
Community Legend
Community Legend
You seem unable to answer ALL questions, try again?
Or give us your DWG file so we can take a look at it ourselves.
Message 13 of 41
DWG in attachment
Message 14 of 41
Select line and change the linetype scale in the properties dialog box to 1. Then the other question is how big will your drawing be?
Message 15 of 41
Doesn't help
Message 16 of 41
What do you mean with 'how big'? How many bytes?
Message 17 of 41
IS this the same as yours? "A", "B", "C" "D" size borders
Message 18 of 41
you can select the line, right click and choose properties. Your ltscale for this line was set to 0.01. This pic is what it looks like when I set it to 10
Message 19 of 41
SeeMSixty7
Your default ltscale for each entity is set to 0.001. That is really small. Setting ltscale at entity level is not something I recommend as this causes issues like this.
Highlight the line. Bring up properties and set the LTSCALE for that entity to 1.0
Good luck
Message 20 of 41
Yep, it's exactly the same.
Where can i find my size borders?
