AutoCAD - Crosses in Blocks
paul.whiteAWFKE
paul.whiteAWFKE
Community Visitor
Community Visitor
Good Morning,
For some reason I'm occasionally getting lots of crosses in my blocks. Line smoothing is set to off / 0 and regen sometimes works (but not on this occasion).
Is there a permanent  fix anyone knows off ?
Thank you
[ The subject line of this post has been edited for clarity by @handjonathan Original: Crosses in Blocks ]
AVCPlugins
Maybe there are point-objects inside the block and their display is configured as a cross.
Either this is a glitch of video drivers and the AutoCAD engine. Update drivers and AutoCAD.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
cadffm
These crosses are real objects like circles or lines too.
Read more about POINT pdstyle pdsize
https://help.autodesk.com/view/ACD/2023/ENU/?query=POINT
You can hide ALL POINTs in your drawing, or you have to edit your block definition (select and erase the points inside)
Sebastian
pendean
Community Legend
Community Legend
Curious if you tried to select one of those, then look it up in PROPERTIES before posting: what did it say those objects are?
TLDR? Set PDMODE command to 0 (that's a zero) then REGENALL command: look up those commands in HELP to understand what that did.
HTH
