AutoCAD2023 w/Epilog 36EXT plotter - Editing Custom paper properties changes back to default custom size
brian.burke97DXJ
brian.burke97DXJ
Community Visitor
Community Visitor
Hi, can anybody help with this issue on AutoCad2023 Educational version. I cannot seem to edit the Custom Paper size. Any time I set the plotter size, and go into Properties to make a change, when I edit Custom Properties like Raster or Vector, and click ok, it changes to a custom paper size that is different to what I had set and I cannot change the custom size. I have added a clip of what happens, paper size was set to 610x914mm and it changes to a custom size of 279x216mm.
The plotter is an Epilog 36EXT Laser
[ The subject line of this post has been edited for clarity by @handjonathan Original: Cannot edit Custom paper size - Editing Custom properties changes to default custom size ]
pendean
Community Legend
Community Legend
Consider creating your custom sheet size in a PDF driver, then print hat PDF to your plotter instead, see if that reveals any other issues with that plotter/driver that you may have overlooked.
