I have discovered recently that the AutoCAD Index Colours (AIC) in AutoCAD are changing when printing.
- When the model space background is set to black the AIC colours give one set of RGB Values
- When the model space background is set to white or any colour other than grey the AIC colours give a second set of Values
- when the drawing is printed using AutoCAD PDF (High Quality Print), the AIC colours give a third set of value
to test this I have set up a colour palette with AIC colours 1 to 255 in a grid labelled with colour number
see below space screen captures
- model space background "AIC colour 253", plot style table "AutoCADLT"
- PDF view, model space background "AIC colour 253", plot style table "AutoCADLT"
- AutoCAD view, model space background "Black", plot style table "AutoCADLT"
- PDF view, model space background "Black", plot style table "AutoCADLT"
to fix this issue
- click plot
- click the arrow in the bottom left of the plot dialogue box to show additional options
- in the top left of the plot dialogue click the drop-down selection for "Plot Style Table (Pen Assignments)"
- click new
- click next
- type a name and click next
- click "Plot Style table editor"
- click on one of the colours on the left and you will its properties on the right, by default each colour will be set to "use object colour" in properties, click the colour dropdown
- in the dropdown, click select colour
- click the "index colour" tab at the top
- select the correct colour or type the colour number in the colour box at the bottom of this dialogue box
- click "ok"
- repeat steps 8 to 12 for each of the 255 colours
- click "save and close" on the plot style table editor dialogue box
- click "cancel" on the plot dialogue box
- right click the layout tab
- click page setup manager
- click modify
- select the correct plot style table
- check the box "display plot style"
- click OK
- click close
- repeat steps 16 to 22 for model tab
